CName Record
Correct. The first entry is the incorrect one but i cant delete it from CNAME.
And there is no reason to delete it either. As long as the names are different, different CNAME records don’t interfere with eachother.
This is still showing Not Ready. I noticed the difference with destinations but how to change? How do i delete previous entries?
From VPanel
Yes
How can I get in touch with an admin to delete the first entry so I can start over?
You have to do it yourself
Also
When I hit delete I get this error.
You gotta wait for admin then
My SSL shows both entries.
You should delete this
Then add in the correct CNAME record
That entry is the correct one which it will allow me to delete.
I just deleted the bottom correct entry.
Good
Now add in the correct one and wait
Got it! Adding now. Thx
YAYYYY! That worked so now I am waiting for the SSL certificate. Awesomeness!
I received the email containing the certificates and i paste certificate then uploaded it. Then I get this error. Im confused!
Upload the private key first. Make sure you copy everything exactly :relaxed:.
I did it again. its was approved. Thanks for ALL the help. Until next time…
