Configuring FTP Client with InfinityFree
Hello,
I am trying to configure the FTP client - EditPlus with Infinity Free. I was looking up this resource on Knowledge Base -
I found the hostname, username and password from the FTP Accounts section in cPanel. Now I want to connect with the Subdirectory which is WordPress installation, how can I do that?
Thanks
If you connect with the credentials presented there, you should be able to connect and navigate to the folder which contains WordPress. If that client requires an Initial Directory to be provided, you can simply enter a single slash: /.
@Admin
Thanks. That worked.
