Hi,
I try to connected the FTP with PhpStorm but I didn’t see the files and folder (htdocs), Why?
How can I fix it?
David.
Hi,
How can I fix it?
David.
Provide a screenshot of what exactly do you see, is it an error, just few unknown for you files, something else?
Try to use MonstaFTP in your panel, do you see the same?
I just tried to connect to FTP from phpStorm as well, and it didn’t work right away for me either.
However, from the Deployment config menu, you can go to Advanced Options and enable Passive Mode there. With Passive Mode enabled, I was able to connect without any problem.
