Username is epiz_27046795
Domain that i want to point out is jnntcs-epizy-com
Domain from wix that i want to use jnntcs-com
There are no error message, but when i wait for 24 hours. I point my wix domain using A and CNAME Records to the IP Address of my account.
The image below shows what i do.
The DNS Record that i changed from wix is
A (Host)
Host Name Value TTL
jnntcs-com 185-27-134-218 1 Hour
CNAME (Aliases)
Host Name Value TTL
www-jnntcs-com jnntcs-epizy-com 1 Hour
I wait for 24 hours. When i check my domains inside of wix, it shows “Your domain is set to point away from WIX”. Which means my configuration is changed
When i access my website, It still shows the suspenddomain.org every time i input jnntcs.com
Although wix is pointing out my domain inside of infinityfree but not showing my actual website just like this.
Is there any tips to fix this? or should i wait for it to work? I just created this account yesterday. Thanks for the help in advance
