when i try to access ftp. it shows this error.
Status: Connection attempt failed with “EAI_NONAME - Neither nodename nor servname provided, or not known”.
For me FTP works fine. Can you try to connect to 185.27.134.11
with a FTP client instead and see if you get the same error?
OK
now it shows this Status: Connecting to 185.27.134.11:21…
Status: Initializing TLS…
Status: Verifying certificate…
Command: USER epiz_24930732
epiz_24930732
Response: 331 User epiz_24930732_epiz_24930732 OK. Password required
Command: PASS **************
Response: 530 Login authentication failed
Error: Critical error: Could not connect to server
The username should not be two times your username, but only one time it! Can you please check if you copied it correctly, and if you didn’t remove the other same username, copy only one of it and use only that to login?
no still showing the same thing. i will try to restart the app
Working now. Thanks
