Connection error: mysql_connect:
My website URL is:
http://tn-st.epizy.com/FTSP-V2-BUGFIX-16-10-18/
and i add Your mysql host address and its same show error msg and im sure when i try this script on my localhost its right no problem in it
My website URL is:
The first thing to note is that the mysql_*
are no longer available with PHP 7.0 and later. These functions are old and should be replaced with mysqli_*
functions or PDO.
So can you please try to change your account’s PHP version to PHP 5.6 and see if that works?
If it doesn’t, can you take a screenshot of the values you entered in the wizard, so we can check if they look OK (don’t share your password, of course).
