Connection refused to MySQL DB
User: epiz_31589084
Warning: mysqli_connect(): (HY000/2002): Connection refused in /home/vol5_7/epizy.com/epiz_31589084/htdocs/test.php on line 6
This is my code:
<?php
define("DB_HOST", "b3f1ezea.epizy.com");
define("DB_USER", "epiz_31589084");
define("DB_PASSWORD", "***********"); # removed for privacy
define("DB_DATABASE", "epiz_31589084_cloud");
$conn = mysqli_connect(DB_HOST, DB_USER, DB_PASSWORD, DB_DATABASE);
if ($conn->connect_error) {
    die("Connection failed: " . $conn->connect_error);
The same code works for another website I own, I am also 100% sure all of the credentials are correct
PLEASE HELP
That is not the database host. The database hostname will looks something like sqlXXX.epizy.com, where XXX is replaced by 3 numbers. The correct database server can be found in the Client Area.
oh thanks, I just realized that.
