Noted, and thanks! @Admin
@Admin i have one more problem… when this connection problem come, and I thought it was my backend problem, i tried restore my other website www.wafiazizul.cf using ftp and MySQL by uploading my last backup website folder and sql file. And now the website is showing just the list on database. Im not sure whats wrong… and I forgot to take the backup before I put my last backup folder. Is there something you guys can do?
error 500 https://infinityfree.net/support/http-error-500/
and it looks like your wp-admin and wp-content directories does not contain any files (just empty folders)
if no backup is available - the only solution is to reinstall WP
If you have another problem, please create a new discussion for it. This topic is about Connection Timed Out errors on many websites, not another error on your website.
I’m using 11_2 volume. Can you try https://brendon.ml/calculator to make sure that it’s working, and that it’s not just me?
http://hedgesfamilytree.rf.gd/ Time out problems for me, can someone check its not just my end. thank
@Karl-Hedges loading a bit long(2-5 seconds instead of 1-2), but it’s okay for heavy sites like your is, it’s ok on my end.
@Admin said:
It looks like the sites are slowly coming back online. It may take a while for everything to be fully up and running, but it looks like the worst of the issue has passed.@mauwiks said:
Is this issue related to the recent migration?From what I’ve been told, no. This issue is caused by an external cause, the timing is just coincidental.
Thanks for the hard work team
thanks
Dear Admin,
user id epiz_22853332,
site down with ERR_CONNECTION_TIMED_OUT… please help.
Hi there, please could you help me my site is set up wordpress as ww.choosegoldira.com but it will not load some reason.
Really Junior ? Perhaps its the mobile version that is not working
whenever I try and load it on my mobile devices it says Error could not find page ( saying I typed out the domain incorrectly or it says Forbidden you do not have permission to access this server
@JustineNeedsHelp I’m currently on mobile, you can use third-party services to check how your site looks from different browser and if site is working at all from other ends.
Junior I think it was just my browser thank you for the help man
But it seems like only a few phones or computers have permission otherwise it does not load
If it’s new site here it can take a while to propagate DNS
I did make it yesterday
