Contact forum ends up error 500
i have download the contact forum from the webpage above and setup with my own details (i have 2fa and im using an app specific password)
but when i fill in the forum to send my webpage returns error 500
any ideas?? (forgot to say on my last edit, im using gmail SMTP to sent to my other account office365)
i can even struggle on putting this in website development or hosting support
It looks that you’ve set it up incorrectly.
First enable display errors.
Warning: include(/home/vol9_6/epizy.com/epiz_2393****/mamasdumplings.cf/htdocs/contact/vendor/composer/../google/recaptcha/src/ReCaptcha/ReCaptcha.php): failed to open stream: No such file or directory in /home/vol9_6/epizy.com/epiz_2393****/mamasdumplings.cf/htdocs/contact/vendor/composer/ClassLoader.php on line 444
Warning: include(): Failed opening '/home/vol9_6/epizy.com/epiz_2393****/mamasdumplings.cf/htdocs/contact/vendor/composer/../google/recaptcha/src/ReCaptcha/ReCaptcha.php' for inclusion (include_path='.:/usr/share/pear/') in /home/vol9_6/epizy.com/epiz_2393****/mamasdumplings.cf/htdocs/contact/vendor/composer/ClassLoader.php on line 444
Fatal error: Uncaught Error: Class 'ReCaptcha\ReCaptcha' not found in /home/vol9_6/epizy.com/epiz_2393****/mamasdumplings.cf/htdocs/contact/submit.php:19 Stack trace: #0 {main} thrown in /home/vol9_6/epizy.com/epiz_2393****/mamasdumplings.cf/htdocs/contact/submit.php on line 19
thats what it states. interesting ive not changed this folder since i downloaded from github.
Can you please verify that you downloaded the “contactform.zip” file? Not the “Source Code (zip)” file? Because like the name suggests, the “Source Code” contains the raw source code which needs additional processing before it can be used. The “contactform.zip” already has this extra processing done, and is ready to use.
