Control panel does not open
Hello
The control panel does not open?
reza23.rf.gd
Explain more than just ‘does not open’
Is it giving a 500? Is is timing out? Please be more specific.
This is not your fault this Internal Server Error.
According to your reply to BayoDino reply
Error 500 means: Internal server error response code you can read more about Error 500 here.
If you are unable to access your Cpanel from your Device than try to access it on other device (e.g. Mobile Phone or other Desktop).
The OP does not respond to his topic and probably won’t in future, that’s why i start with a very basic question rather than just giving a proper answer.
Thanks, the problem was solved
