I keep getting the error
“Could not access your domain. Please make sure your domain is pointing to this server and there is no .htaccess file restricing access to your domain”
Whilst trying to install OSSN via Softaculous.
Does anyone know a fix for this?
Hi
You did not follow the template…so please tell us what is the address of your website ?
If everything is fine with your domain as far as NS is concerned
it is possible that the security system reacted during installation
however, OSSN is not suitable for this hosting for several reasons
and also there have been cases of it being suspended after 2 hours of installation because it eats too many resources
I am only going to be getting around 10 to 15 people be using my OSSN website, so would it still be okay to use it or will it still take too many resources?
Depends on what those users do. If they are just 10-15 rows in a database, then it’s probably OK. If those are 10-15 people online simultaneously refreshing the page repeatedly to see the latest posts, you’re going to have a very bad time.
