Cpanel down?
Cpanel is not loading, my website is also down, anything wrong?
I have the same problem,:frowning:
:pensive:
Hopefully they will fix it soon
It will be nice if someone can confirm is not a problem from our side
Also a problem for me.
You can look at the forum homepage, Bunch of posts saying cpanel / Website down. So it’s probably a error from their end
fixed on my pc
My website is back up
Check yours maybe it’s too back online
My website is still not online:pensive::pensive:
Ya it was up only for some time, mine is also down now
is this a normal thing with this site_
sometimes, not always
This is the first time i’ve seen the site down in the past year. So far, they are accurate with their 99% up time offering. These things happen and I’m affected as well. Won’t be much longer before the sites are back up :slight_smile:
Is the website down as well? I can’t login to ftp either and the website says Bad Gateway 502
There was/is a major system issue which caused everything to be down earlier today. There is more information in this topic:
