This is not a site issue. This is an issue with your cPanel.
When you go to open up “Softaculous Apps Installer” the installer page say’s this:
Something went wrong, please allow 20 minutes then retry. It constantly says that.
As of right now, Softaculous does not work.
Here’s a screenshot.
CNAME is available and has its own separate section under “CNAME” in the control panel.
Could you please post the username of the account that is having issues? Please don’t deactivate it, otherwise, we won’t be able to check it out properly.
Uh yes, I see the CNAME Records. I should’ve looked there. Thanks.
For the account, epiz_29558076 is the one with the Softaculous issues. I assumed maybe removing the htdocs/index.html would solve the problem. Somethings up with that one. I did just make the username: epiz_30931300 and it shows.
The index file is just a “Your website is all setup” thing, it won’t affect Softaculous. Since your new account is working fine, my money is on the fact that the server misconfigured something when it was setting the account up.
I actually do not have access to client accounts outside of the forum, I only asked you to provide the username so Admin could look into it and possibly report an issue.
Yeah, I have no idea what caused the issue. I am a bit more limited here than I am with NameHero to do more investigation. As of right now, I’ll leave it. Thanks for your time. I just the Admin can look at it.
