The CPanel ssl is expired,i can’t acces it.
Usually browsers allows you to access website if you find the right button.
I guess as soon as it’s possible it’ll be fixed.
I've forwarded the issue to iFastNet to get it fixed.
The control panel is using Let's Encrypt certificates which are only valid for 3 months. Unfortunately, the way they are currently being installed is not very robust, because this same issue happened three months ago as well.
Is not possible to use CloudFlare?Admin said:I've forwarded the issue to iFastNet to get it fixed.The control panel is using Let's Encrypt certificates which are only valid for 3 months. Unfortunately, the way they are currently being installed is not very robust, because this same issue happened three months ago as well.
TudorLodroman said:Is not possible to use CloudFlare?Admin said:I've forwarded the issue to iFastNet to get it fixed.The control panel is using Let's Encrypt certificates which are only valid for 3 months. Unfortunately, the way they are currently being installed is not very robust, because this same issue happened three months ago as well.
On the control panel, no, for many reasons. And there is no reason to, because there is Let's Encrypt integration already.
