Hello, could you please check what the error is? I think the Red Line is not supposed to be there. A few days back, the red line was at some more height.
The reason the graph changed was because the graphs for active and suspended accounts didn’t match. This was “fixed”, but it does look like the new position of the red line is not correct. I’ve asked iFastNet to investigate.
Thank You.
iFastNet has fixed the issue now. You should fine the red line is a lot higher now (and matches actual suspensions again).
