I didnt recieved any cpu usage warnings.
Shouldn’t I recieve that warning e-mail says CPU USAGE 50%!
My website shutdown immediatly without any warnings
If you haven’t changed your email address then it should go to spam folder. isn’t there any emails?
Or probably because that reached cpu usage quick.
Are you using PHP? Your code may be inefficient.
Either your CPU usage spiked so quickly you exceeded the limit before we could warn you. Or the warning email was sent, but was not delivered to your inbox for some reason (spam, blacklisting, etc.).
