My website is https://secrety.jeejee.cf , and always when I update my css it doesnt update, those user and pass should be in middle.
Try:
Pressing CTRL shift R - You activate the function with the keyboard shortcut Ctrl - Shift - R , Shift -F5, or by holding down Shift before you activate the reload button. Chrome ignores the cache and will load all resources from the web page again. ā¦ It includes the empty cache and hard reload option that you may use.
Or go in incognito mode
And yes, the uname and password are in the middle
This happens because of caching. CSS files are mostly static, therefore browser stores it. Refreshing browser cache will fix this.
didnt work tihe me when did everything u said used opera and chrome. Seems like pc issue or smth.
interestingā¦
Usually it works for me
Try clearing your cache if you havenāt
did it too
I can try it again
I see youāre using Cloudflare on your site. Please understand that all the performance enhancements of Cloudflare are primarily achieved through caching. Cloudflare speeds up site by caching your site in their edge network across the world, so the cache is served quickly to your visitors.
So if you want content updates to be visible immediately, you need to implement some cache busting system in your website, or just donāt use Cloudflare.
EDIT: I also merged your topics. Please donāt double post. Next time, both topics will be deleted.
I have developemnt mode on that disables caches, and have cleared cached hasnt work still.
you are using cloudflare got to https://dash.cloudflare.com/username/website/caching/configuration/
and click purge everything
then in your website use ctrl + R or ctrl + F5
didnt work
Please make sure to first enable Develoment Mode in Cloudflare, and then clear your browser cache (or just check the site in Incognito mode).
And IIRC Cloudflare automatically disables Development Mode after a few hours. If you want Development Mode to be permanently on, donāt use Cloudflare.
i dont use Development Mode
and also Incognito mode
And thereās your problem: if you donāt bypass the cache in your browser AND in Cloudflare, youāll keep seeing old content.
