css not working after applying https by cloudfare
you can see here
https://bloggersgroup.in/
hi
please try this one https://support.cloudflare.com/hc/en-us/articles/227227647-How-do-I-use-Automatic-HTTPS-Rewrites-
and then purge cache from CF
if it did not help let us know
you can see here
Are you using Flexible SSL? I had the same issue as you and it solved when I selected full SSL.
Flexible SSL breaks most WordPress websites, I am telling this from personal experience.
Also, do what @OxyDac said if you haven’t done already.
can you tell me steps becouse in infinity account thare is no seting for flixible ssl
you can see here
What the problem is you’re serving insecure HyperText Transfer Protocols (HTTP) and Secure Sockets Layer (SSL) only serves for Hyper Text Transfer Protocol Secure (HTTPS).
Meaning, your connection isn’t 100% safe.
So, simply replace your http://
s with https://
s in your code and it’ll resolve all errors. In your Source Code you’re showing sources starting with //
which isn’t transmitting a Protocol.
So, just make the change or under your Cloudflare turn on Force HTTPS Rewrites
. Which will still render the insecure
issues until your code also meets HTTPS requirements.
I’ve had the same issue, once I made the change it fixed everything.
Also, you’re probably going to have to Purge Everything
under your Cloudflare Caching.
sory for thare is no seting in cpanel of cludfare for i need open a account in cloudfare than redarect the nameserver thare but after these it will not point for infinity
Cloudflare does the magic and “tricks” the Name Servers so your website will remain online. When you register for a Cloudflare account your domain needs to have the current Name Serversns1.epizy.com
,ns2.epizy.com
then you’re going to set up your domain name through Cloudflare. When Cloudflare says to change your Name Servers you do it. You change them fromns1.epizy.com
,ns2.epizy.com
to what Cloudflare provides you then continue through the guided setup.
Then under your Cloudflare Overview Dashboard you should see “Force HTTPS…” just enable all of them because you ALWAYS want to use HTTPS.
server ip address not found
i did that but it is not working
Your site seems down (or is it just me?), you might want to check it out first.
No matter if your site using HTTPS or not, when your browser cache isn’t (force to) refresh/reload, the page may still look like the old one, though we’ve updated them to newer version of script. Try pressing Ctrl (or Cmd if using Mac) + F5 to force browser to get new cache of the site.
In the other hand, flexible SSL may also affects your site as everyone stated above.
Flexible SSL known to bring many side effects in here, commonly about infinite looping/redirection and broken page (which I don’t really understand, but that’s what happened).
And according to Cloudflare, Flexible SSL secures the connection between client and Cloudflare, but not between Cloudflare and server (InfinityFree)
@Ashutosh4841 said:
https://bloggersgroup.in/ you can see that here
We can’t able to see your site because DNS_PROBE_FINISHED_NXDOMAIN kindly add an A records pointing towards IP of your site or change nameservers
Follow the steps as Ive mentioned above. Your site is experiencing DNS routing issues. You need to assign the appropriate DNS records as I mentioned above. I can only help if I know whats going on. May you post a screenshot of your DNS Redords and Name Servers for further assistance?
What the hell going on here.
The problem, probably, is that he tryin to access unsecured http from secured https. Google chrome, for example, blocking that requests and CSS not loading.
Tip: in tour pages, use not ‘https://’ or ‘http://’, use ‘//domain.com/file.css’, it will pick up https if available/needed
The problem, probably, is that he tryin to access unsecured http from secured https. Google chrome, for example, blocking that requests and CSS not loading.Tip: in tour pages, use not ‘https://’ or ‘http://’, use ‘//domain.com/file.css’, it will pick up https if available/needed
When there no A record nor a CNAME record than how you can access a site?
You made his site offline lmao. He did like you said, some shit with nameservers and other stuff. I just said what he could do at the beginning.
You never needed to change nameservers!
First, as @MrJunior stated, your site is offline, so change your nameservers back to InfinityFree ones.
Then, go to cpanel-CloudFlare, and enable CloudFlare for your domain. (Make sure you delete it first from CloudFlare before you re-create it).
Go to the Crypto section, and select Full SSL, then also select Automatic HTTPS Rewrites and Always use HTTPS.
Exactly.
