jojokers.cf
I don’t know how to fix these
for hours I tried fixing(googling and stuff)
And since it says “contact host provider for a fix”
jojokers.cf
Ignore it if website is working.
This is free hosting.
Likely due to this.
I do not intend my website for file sharing tho
It means that since the checker is not a web browser, the server is probably blocking it so it cannot check it. If your site uses SSL/HTTPS, than just ignore the message.
I cant use arc.io with it since theres an error " The certificate is not trusted in all web browsers. You may need to install an Intermediate/chain certificate to link it to a trusted root certificate. Learn more about this error. The fastest way to fix this problem is to contact your SSL provider."
Use CloudFlare. Follow this guide
