Just a blank white screen that says loading… when I try to customize website.
I have tried to clear cache, change browsers, change themes, deactivate plugins, no luck. I am willing to try them again or anything else before I restart.
The website looks fine for me. Are you experiencing this error in wp-admin? If so, can you share the plug-in name and a screenshot of the error/malfunction? Thanks!
I see you are using Cloudflare on your domain. How did you set that up? WordPress + Cloudflare can result in some inexplicable issues if setup incorrectly.
You can use either Flexible SSL together with the Really Simple SSL plugin, or you can request and install a self signed certificate and use Cloudflare with Full SSL. Just whatever you do, do not use the Automatic HTTPS Rewrites option in Cloudflare, because it creates issues like this.
