Hi!
@Admin .
I just want to ask a simple question when I see my resources daily they are very below to the limit like CPU usage, hits. When I see it was 1000 outof 50000 but after that in few hours it I don’t know who becomes 50,000 outof 50000 , I used all CPU resources while in just one hour, how?
Is really accurate measure or forcing to upgrade?
@Ranakhas said:
Hi!
@Admin .
Hmmm Good Question!
I had this type of problem on my other PREMIUM HOSTING account and I used all the resource in 10 minutes?
The site is just a Wordpress and I did nothing to it (No updates, etc.)
This topic will be interesting
Cloudflare is the best for this. Use strict mode on cloudflare instead
If your website is being used intensively during that hour, then it’s definitely possible to use a lot of the resource limit in an hour. However, you should also note that the counter doesn’t update right away. I don’t know exactly how often it updates, but it doesn’t update immediately.
