I’m creating my own little blog system. My blog system will be very easy, just some posts on the page with no admin panel etc. I cannot get the results from the database on my page, is this something that is not possible with a free infinityfree account? I’m using this code:
include “includes/db.php”;
$query = “SELECT * FROM blog_posts”;
$posts = mysqli_query($conn, $query);
if (mysqli_num_rows($posts) > 0) {
while ($row = mysqli_fetch_assoc($posts)) {
echo $row[‘post_title’];
// And all the other rows…
A database which can’t execute a simple SELECT query would be completely useless, so that’s probably not the issue here.
As I see it, I suspect the problem is either:
The table you’re querying is in fact empty and not returning any rows.
The query is returning an error which flew under the radar.
Your code snippet is a bit short, but I don’t see any error checking codes in there. Try checking whether the connection was successful and whether the query returned any errors:
