saboor
January 25, 2021, 6:47am
#1
Hello everyone, I upload my project everything is not working fine except the data, data is not fetching from database even though the username, password, and database is correct
define(“DB_HOST”,“sql107.epizy.com ”);
define(“DB_USER”,“epiz_26057592”);
define(“DB_PASS”,"HIDDEN BY MOD
define(“DB_NAME”,“epiz_26057592_XXX”);
21
And what error do you see?
Your actual database name.
@anon19508339 Is there a way to also hide edit history? Even you hide the password, the original text is still there.
saboor
January 25, 2021, 7:19am
#5
Sure the password is hide on the dashboard, but on the script its not hidden
here is the actual database details
You should create a Database from Vpanel and Use that Database name XXX Resembles the Database name you create in Vpanel
Also it’s recommended to change the password
saboor
January 25, 2021, 7:26am
#8
Well I did create database from Vpanel and I select the name which is generated automatically for me.
saboor
January 25, 2021, 7:27am
#9
That is good point, but the project is not really to big nor important
Bro…Privacy is important and It is Single password which helps me to even Log into you control panel.
saboor
January 25, 2021, 7:34am
#11
anon12237952:
panel
Yeah I know that is important, but for now I just want to solve the problem after I can change it
saboor
January 25, 2021, 7:36am
#12
Okay I delete the database and I will change the password too, now you cannot get into the control panel hehe
Admin
January 25, 2021, 9:57am
#14
What’s there to tell? The table POST
indeed does not exist. I only see a table post
rename it to POST? the hosting is case sensitive.
saboor
January 25, 2021, 12:44pm
#17
Okay thank you, I solve the problem
system
Closed
February 9, 2021, 12:44pm
#18
