I am using php to connect myphpadmin. However, since the result contains chinese characters, when I display it on website. The character becomes ??? instead.
May I know how can I solve this problem? OR
This is the limitation on infinity free free hosting?
Or if you want to change the charset in a specific database, then go to phpMyAdmin and Choose the database that you want to configure and then go to the Operations tab, you can see the option to change your charset there for your specific database.
HI UnknownLolz,
I have tried to update the collation, but it looks the same result. I think that this is the limitation of infinity free? OR you have made it work before?
Hi UnknownLolz,
Thanks for your reply again. It is a online store site which host product list. It write with html and php.
Currently, I am using php to retrieve mysql data and using jquery to modify the html content. However, it is found that the return data become ??? if the data include chinese characters.
I have tried below to solve the problem.
Add
Change the collation in phpadmin
BTW, the chinese character show correctly if it hardcode in html content.
