PHP doesn’t support Array and string offset access syntax with curly braces. It has been deprecated.
Basically I want to link my database to php script but it gives me an error cause in “epiz_27840026_XXX” the character underscore “" is creating issues. Can someone help me. Is it possible to fix? If I create a database without underscore "” it gives me this issue
That’s a deprecation warning. It doesn’t mean that something is broken, but it does say that the software should be updated because it may not work with newer PHP version anymore. A well written application doesn’t crash on them but just logs them and move on.
I’m pretty sure (or at least I hope) that’s not because of the underscore. The most common reason for this error are described here:
I hope your software doesn’t break on an underscore it a database name. Every hosting platform I know creates database names like username_databasename. If your software doesn’t support it, I doubt you’ll be able to find a hosting service for it.
Oh ok that’s most probably it the software has lots of issues even when hosting it locally it was broken so I thought it was cause I was running a local server so I guess the script is well written. Ah Thank you so much @Admin .
