I have a installer code ask for when i put in my database and password nothing happens.
No error code nothing. need suggest as i suck at mysql
MySQL Driver |
MySQL StandardMySQLi Enhanced |
Hostname |
This is usually localhost |
Username |
The user must be able to use the database |
Password |
Database Name |
The database should not have any other software using it |
Oxy
2
Hi and welcome to the forum
Can you tell us more information e.g. application name ?
Do you do that via Softaculous app installer inside Control Panel or Manually?
https://infinityfree.net/support/common-mysql-errors/
https://infinityfree.net/support/how-to-setup-a-new-mysql-database/
connects to the mysql and loads up variables within the game
I tried to upload install. php file but wont let.
Admin
4
What won’t let what? Can you please explain the issue in a bit more detail?
system
Closed
5
