Database connection error
Hi Guys, I am getting an error connecting to database error, when I set the wp admin to true then I get this error
Warning: mysqli_real_connect(): (HY000/2002): No such file or directory in /home/vol11_6/epizy.com/epiz_22406000/htdocs/wp-includes/wp-db.phpon line 1531
Deprecated: mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol11_6/epizy.com/epiz_22406000/htdocs/wp-includes/wp-db.phpon line 1562
Warning: mysql_connect(): No such file or directory in /home/vol11_6/epizy.com/epiz_22406000/htdocs/wp-includes/wp-db.phpon line 1562
Any clues what I need to do? Cheers
It can’t find a file or directory or a missing line code.
It looks like you are using some MySQL stuffs that is deprecated on the free hosting servers.
You should use PDO or Mysqli instead of what type of MySQL you are currently using.
Please see this article: Common MySQL Connection Errors - Docs - InfinityFree Forum . There is a section about “No such file or directory” in it.
Next time, please check the knowledge base first before posting, as many questions are already answered there.
