Delete SSL certificate
Username : epiz_32146161
I want to delete ssl certificate for ms365cloud.tech
ERR_TOO_MANY_REDIRECTS
You can stop using your SSL certificate by deleting the record you put for your SSL and delete the records in vPanel/Control Panel.
I hope this helps, I’m not sure if my answer is correct but try it out.
This is what I see
What is on your domain dns entry?
