im working on digital asset link and i always get a fail verification, the requirements are correct as it works in my current hosting.
i am hoping to get the same result here as i plan to transfer hosting providers if i am satisfied. are there issues on the free ssl with regards to verifying digital asset links?
i have placed the .well-known/assetlinks.json file/folder in htdocs.
Here are some possible uses for Digital Asset Links:
Website A declares that links to its site should open in a designated app on mobile devices, if the app is installed.
Website A declares that it can share its Chrome user credentials with website B so that the user won’t have to log in to website B if it is logged into website A.
App A declares that it can share device settings, such as location, with website B.
While I’m not sure but I think this is because of the security system. You might want to read this KB article:
hi. yes. that’s the one. the file requirements are all correct, even inside my android app. i have a different hosting site and it works if i use the subdomain or main domain there.
but if i use the subdomain like infinityfreeapp or epizy, verification fails.
my android app actually uses a trustedWebActivity which is a Chrome browser instance so it should not apply to that security restriction. the purpose for this is that the toolbar can be hidden if verification is successful for .well-known/assetlinks.json from the app to this file communication.
or… can an @Admin please confirm this, if it falls under the security restriction?
I have a very limited knowledge of how this Digital Asset Link work so I apologize that I may not be of a help to you, once Admin will be online, he can help you.
As what I understand, your app will be accessing your site and will look for assetlinks.json in your hidden .well-known folder to verify? This is a little bit similar to the file verification method for getting Let’s Encrypt certificates (uploading the file used for verification in the .well-know folder) on web based platforms (like SSLforFree) but the verification will fail as it will be blocked by the security system. So I am wondering how your app checks the file for verification?
Also with the verification issue what error messages do you get? Do you get an Error 403 forbidden or something?
<html><body><script type="text/javascript" src="/aes.js" ></script><script>function toNumbers(d){var e=[];d.replace(/(..)/g,function(d){e.push(parseInt(d,16))});return e}function toHex(){for(var d=[],d=1==arguments.length&&arguments[0].constructor==Array?arguments[0]:arguments,e="",f=0;f<d.length;f++)e+=(16>d[f]?"0":"")+d[f].toString(16);return e.toLowerCase()}var a=toNumbers("f655ba9d09a112d4968c63579db590b4"),b=toNumbers("98344c2eee86c3994890592585b49f80"),c=toNumbers("d3c143e907c1d71f78f0018d7dbf3ac7");document.cookie="__test="+toHex(slowAES.decrypt(c,2,a,b))+"; expires=Thu, 31-Dec-37 23:55:55 GMT; path=/"; location.href="https://hans.epizy.com/?i=2";</script><noscript>This site requires Javascript to work, please enable Javascript in your browser or use a browser with Javascript support</noscript></body></html>
