Hi,
I’m trying to host my minecraft server website using azuriom cms,
But for the Installation, he say : Function symlink enabled
You need to enable this function in the php.ini file of PHP by editing the value of disable_functions
How do i disable it ?
Screen : http://sysybigbrain.tk/Wkzkv
KangJL
#2
This is not available on free hosting
Unfortunately, you cannot edit the PHP.ini file of free hosting. If you would like this feature, you will need to upgrade to premium.
Thanks
system
Closed
#4
