I want to use Wooshark dropshipping plugin. In connecting to store step, I received this error.
This error is also for ( Dropshipping and Fulfillment for AliExpress and WooCommerce) plugin where the error is (Error: cURL error 60: SSL certificate problem: unable to get local issuer certificate.). Googling said that
“Your site blocks rest API request from our plugin If you do not have any firewall plugins active, the most possible reason is from your host’s firewall. Please send them the screenshot.”
The “SSL certificate problem” is caused by the fact that our hosting platform does not support uploading the so-called CA Chain with the SSL certificate. The CA Chain can be used by systems connecting to your site to verify your certificate is from a valid provider. All modern browsers work just fine without a CA chain, but automated tools (like the API calls from the drop-shipping partner) tend not to.
But even if you would be able to fix that, you would run into the browser validation system.
