I’m getting DNS_PROBE_FINISHED_NXDOMAIN Problem since 3 days. I dn’t know why It is occur. Site was running perfectly but Suddenly I have deleted all CNAME Record’s. After this I m regularly getting this error…??
Create two CNAME records, one with the name of @ and value of the Main Domain that you can find on the Control Panel, then another one with the name of www and value @. Save the changes and wait for DNS propagation.
You need to go on where you’ve registered your domain and change the DNS records from there.
To use CloudFlare, you can sign up from here and change the nameservers, on where you’ve registered your domain, to CloudFlare ones.
You enabled CloudFlare in the cPanel! Now disable it from the Panel, then go to dash.cloudflare.com, add the domain again selecting the Free plan and adding the DNS records on the post 2 and changing the nameservers to their, removing the other ones.
Just click on it, scroll down and click on “Remove Site from Cloudflare”. Then click on “Add Site” and re-add it, but NOT with the www. part, only your domain!
