Your domain name has an unknown nameserver ns3.netim.net
configured in addition to our nameserver. Please remove that nameserver from your domain, and only use ns1.epizy.com and ns2.epizy.com. After 12-24 hours, you should be able to verify your domain successfully.
If it still doesn’t work 24 hours after removing the bad nameserver, just reply here and I’ll take another look.
Hello, same is issue with my DNS status, for the past 3 months im waiting. the other one is ready and the other was not.
I put the correct nameservers ns1.epizy.com and ns2.epizy.com.
hope you can check mine too.
thanks
Please provide your website url so we can check
mine is here http://ninanonisaportfolio.cf/
convert it underconstruction, both dns not ready
will be greate if you can help me to fix. Thanks!
Your NS hasn’t propagated!
Check here^^^^^^^^^^^^^^^^^^^^^^^^^^^^
You need to delete the _acme-challenge.www
CNAME record and add it again with the correct destination field for that subdomain, and not the same one as _acme-challenge
. After that, you need to wait from a hour to 24 hours and the status should be ready again.
Okay, will re do it again. thanks
