do I need to keep the nameservers after setting my domain to keep it running?? because i need modify my dns records, and in infinityfree I can’t
If your using an external software like Cloudflare, once your account is created, then you can change your nameservers to something like Cloudflare and then manage the DNS from there.
ok, but my domain will still work in infinityfree?
Yes, your hosting account will still work.
The nameservers are only used for the initial verification. After that, the domain name is assigned and will keep working.
Just make sure you configure the DNS records in your own nameservers correctly.
