Do not include www in your entry
I own a domain on “Strato.de” and I’m not able to change the Nameservers to the NS from InfinityFree so I decided to create a new Subdomain (“www.myDomain.org”) and add it to InfinityFree because on Sub Domains I can change the Nameservers. All set up, I tried to add the Sub Domain to InfinityFree but I always get the error “Do not include www in your entry”. But I have to include www because it’s my subdomain.
www.strato.de is same with Strato.de, that’s why it does not let you to add a domain with www, and also you cannot add the subdomain either if you don’t add the main domain.
I think I managed it now. I just created a new Subdomain on Strato and called it “de.myDomain.org” and now it worked. Then I created a redirect from “myDomain.org” to my new subdomain and I think this should work now
