Hello.
My website URL is https://yourzombiemop.com
My account username is epiz_28307539
I am here to ask whether or not a redirection from the ?i=1 suffix link would be a violation of the TOS of InfinityFree; I have tested and confirmed usage of a .htaccess script that redirects an end user after the validation cookie (__test) has been installed.
.htaccess
RewriteEngine On
RewriteCond %{QUERY_STRING} ^(.)i=[^&]+(.)$ [NC]
RewriteRule ^(.*)$ /$1?%1%2 [R=301,L]
Source: .htaccess - How to disable "?i=1" parameter in URL - Stack Overflow
It does not interrupt or circumvent the validation process, it simply redirects all users to a URL without the ?i=1 suffix, while retaining the validation cookie (__test).
Example
…/projects?i=1
would redirect to:
…/projects
This is simply for user convenience and appearance’s sake. It may also allow me to use APIs that have trouble with the ?i=1 suffix in the future as well.
After reading through the TOS a couple of times, I don’t see anything against this behavior. Still, before adding this server-side, I’d like to get confirmation from a moderator that implementing this script is allowed.
TL;DR: Is redirection via .htaccess from a URL suffixed by ?i=1 to a URL without this behavior acceptable under the InfinityFree TOS?
Thanks,
-Matthew
