Does anyone use Ezoic?
Does anyone use Ezoic and does it run correctly? Can you use the ad placement tool? Or does it not work? Is there a better solution that yeilds better results that is easy to setup?
I believe the answer is no to all
https://forum.infinityfree.net/search?q=ezoic
I don’t see a reason why it wouldn’t work for a private domain. For subdomains I see issues. So nobody has used Ezoic here?
Did you really read this thread?
Below is Admin reply
I did read it and have not had any of the issues described in those threads. I also may have read one of those threads wrong …but it sounded like one of those people got it to work. It was not clear and that was what triggered this question. As it basically ended with thanks I figured it out or something of the sorts.
