I was just wondering if I have a problem or if I should be waiting this long, I have bought a domain and have changed my name servers to ns1 epizy com and ns2 epizy com (I removed the dots due to only being allowed 2 links in this form).
It has been almost 42 hours since I have changed them and it still wont let me create my hosting account with my custom domain. It comes up with the error message “Your domain is not yet pointing to ns1.epizy.com and ns2.epizy.com. Change your nameservers at your domain registrar and wait a few hours. You can also create an account with a subdomain first.”
I checked using DigWebInterface and the nameservers are still pointing to Porkbun ones. Did you make sure you changed the nameservers from the custom nameservers section of Porkbun’s control panel? If not could you change them from there? If you already changed the nameservers from there but still the nameservers aren’t changed try to contact Porkbun support for help?
Oh thank you so much, I realize I had changed it in the wrong place. What would the default name servers box be for then, should I reset those back to the original default ones?
