Hi, i did domain redirect from my basic domain into new one which i bought, but now when i try to open this domain its shows me some website with Directory listing which i do not know what to do.
Can i just redirect my website to new domain?
How can i find these docs? when i try to log in through File manager i can not login, should i use as host : ftupload.net? or that ip?
I am getting error :
Does anyone know how to fix that? i can not even log into FileZilla with these, but all requirements like pw, username, host, i checked many times and it is correct.
Never take a screenshot of monstaFTP so that it contains the address bar
in that way, anyone can get into your FTP
I edited your screenshots so that it does not contain the upper part where the address is.
Thank you,
Do you have experience with filezilla? i tried everything and i am gettin error : Etimedout, or Connection timed out after 20 seconds of inactivity. I am lost, i tried everything.
You can also try monstaFTP after that (only it is not for uploading a lot of files)
but you can see if you see files etc. on the hosting
and whether the login to FTP was successful
If you think that something is wrong with filezilla, then send us the full log
if it says in the log that “you should be faster next time”, then everything is probably fine, but the server kicked you out due to inactivity.
Now its working in MonstaFTP somehow, i can log my files, so how can i transfer them into new domain file space? i tried to copy and paste but this is not working.
Could you tell us what kind of website you have?
Is it WordPress, some forum or ordinary HTML ?
I ask this because it is not enough to just upload files if it is a dynamic page
but it should also be connected to the database and other configurations to reflect the new address, etc.
Just take it easy and try to understand what you are doing first
then consult online,
and then you go do something.
Of course, it is always convenient to have a backup on a local PC.
I’m going offline now, but someone else will help you - Good luck
then edit the base URL to impweb.site (config file for impweb.site)
so the new address is entered
because probably when you get to impweb.site
htaccess (or config file) says it’s the right address (but wrong) smartez.42web.io
because it reads the copied config file from the old address
and when it comes to it…it redirects to impweb.site
and an infinite loop
I just guessing what the problem might be
you are a webmaster and you must know what you see and what you do
