The domain appears to be pointing to the host. But it is not showing the correct directory. Instead, it displays ‘Parent Directory’
You can navigate through to the /build/build directory, but when clicking on this it displays the default InfinityFree ‘lets make something awesome’ page.
I have changed the default directory in Prestashop to “/” and set a 301 to force the judgeandstoker.com URL to display in the browser.
Unfortunately I can no longer access my site at either URL. Not too sure what to do!
Thanks in advance
J
Hi,
You should move your files from http://judge-and-stoker.rf.gd/build/ to your new domain.
@PandaVanPresto said:
I have logged in via FTP and moved by files into:
judgeandstoker.com/htdocs - my site is still inaccessible. Could you let me know what I’ve done wrong?
I checked your account, and I think I can see what happened.
judgeandstoker.com is currently registered as Parked Domain on your account, on top of judge-and-stoker.rf.gd. As you can see from the Addon Domains page, the directory for judge-and-stoker.rf.gd is htdocs, not judgeandstoker.com/htdocs.
As I see it, there are two ways to fix this:
Remove judgeandstoker.com as a Parked Domain and add it as an Addon Domain. That should point the domain to the directory judgeandstoker.com/htdocs.
Fix the directories for judge-and-stoker.rf.gd. That should fix judgeandstoker.com as well.
