Hi there, I’m not particularly tech-savvy and as mentioned in the title, I was trying to transfer my site/domain from Ionos to Infinity free, but I couldn’t find an easy or simple way like copy the code authorization and start the transfer. I was told on some other site that I should first change the nameservers on Ionos first. can someone please tell me how to do it. I’d appreciate it very much. thank you.
Hello. InfinityFree does not offer domains, so you will have to keep your domain on your current regisrar. The nameservers you should set for your domain is ns1.epizy.com and ns2.epizy.com. You can follow the guide below to learn more.
ok I see, thanx for your answer;)
