i tryed
185.27.134.11
ftp.epizy.com
ftpupload.net
ftp.upload.net
with user
epiz_22204509
change the password and nothing
filezilla
conecting to server…
time out…
please help
i tryed
185.27.134.11
ftp.epizy.com
ftpupload.net
ftp.upload.net
with user
epiz_22204509
filezilla
time out…
please help
@moassama said:
i tryed185.27.134.11
ftp.epizy.com
ftpupload.net
ftp.upload.netwith user
epiz_22204509change the password and nothing
filezillaconecting to server…
time out…please help
What port did you use?
Could you please paste the full log output of FileZilla here? Some people are disconnected because an FTP command takes too long, but others are not able to connect in the first place.
@UnknownLolz said:
ftp.epizy.com
ftpupload.net
21 or none, the result is the same
Status: Resolving ftpupload.net address
Status: Connecting 185.27.134.11:21 …
Error: Connection timed out
Status: Waiting to try again …
seems unable to resolve the address…
i am from Brazil, usually we don’t welcome butt i´m a nice guy
@moassama said:
@Admin said:
Could you please paste the full log output of FileZilla here? Some people are disconnected because an FTP command takes too long, but others are not able to connect in the first place.Status: Resolving ftpupload.net address
Error: Could not connect to serverseems unable to resolve the address…
You can see the right IP address there, which means resolving the address works fine.
Could you please try this from another device and/or network as well? It has happened that some ISPs have blocked access to some of our servers.
nothing… i try on my mobile and another windows computer (i use linux) the same result
i edit filezilla setup to timeout = 0 and…
“ETIMEDOUT - Connection attempt timed out”.
you can try a less secure protocol (ordinary FTP)
under the file menu choose > Site Manager
and in the Encryption set it to use plain FTP (insecure)
and test
@OxyDac said:
you can try a less secure protocol (ordinary FTP)under the file menu choose > Site Manager
and in the Encryption set it to use plain FTP (insecure)and test
thanks but was already set
guys?
work´s fine
try another FTP client instead of FZ
Also, for example, my ISP has a firewall on its side
and I can adjust 3 levels. (low, medium and high)
check on your ISP user pages
router settings that can make problems
things like: turned on> Port Scan Protection, DoS Protection, NAT Acceleration, etc.
windows firewall (allow app)
thanks,
i il try
np and yw - good luck
and give us the result
