Hi
I’m trying to set an email account on my infintyfree website.
The website is: http://sola-shower.com/
I made a zoho account and i modified the MX records on the cpanel
I can send emails but not receive anything.
What can i do? thanks
Hi
Your domain is using our Cloudflare integration, which breaks MX records and subdomains. To fix that (and so have working emails while still having Cloudflare enabled) you need to disable the Cloudflare integration from the Control Panel for your domain, then delete the domain from Cloudflare, wait 48 hours, then add it manually on Cloudflare.
Ok got it.
I disabled cloudfare. I’ll just wait for my email to work as i don’t need to enable cloudfare
Thanks
