I was trying to white list those IPs.
ok let’s keep that aside, what about my friend’s site, it was Wednesday he login last for practice and the site also went down.
its bothering me alot
did you know that…
| FAILING 2 PLAN…IS PLANING 2 FAIL |
Edited by the moderator - Please don't post memes in this category! Thank you.
As I said earlier, can you please provide a domain and username?
Thanks.
Try this:
deny from all
allow from 11.234.567.890 12.345.678.900
That site has a corrupted WP installation. That has nothing to do with InfinityFree. (Although a iFastNet server upgrade may have caused it.) Please follow this article to repair the site.
Edit: Sorry, I copied the wrong link
Link, you didn’t add it
I removed the installation and started afresh to rebuild it today
Ok, I recommend to take a backup of files AND the PHPMyAdmim Databases whenever you make a big change (Or every x days) so you don’t have to re-build
Ok, I knew that before, but for some reason… the logic got reversed in my head XD
Yeah, don’t do
allow from whatever
deny from all
do
deny from all
allow from whatever
Order does matter (as already stated here)!
Please can you write the script here for me, if am trying to whitelist a certain IP rangs. I the I use was a recommendation from someone I copied from.
Is this what you want? I posted it above. Just replace my example IPs with the real ones. You can add as many as you want.
thanks a lot.
Not a problem!
I merged both the topics.
Next time @emmapsky if you don’t understand a provided solution or the solution doesn’t work, please just say so and ask! As you found out, we’re all happy to help you. But please try to keep an open mind and consider the solutions presented to you. Ignoring a good part of them because you don’t believe them makes it hard to solve problems.
