Hi, I just added my own domain on the cPanel and it was successfully added and then when I enter the domain I added, It will directed me to the infinityfree site with the error message of 404. Any suggestion about this problem? Thanks in advance.
Did you upload something to the htdocs folder of your new domain?
I saw one of my added domains folder but I can’t find the other one.
In that case, the folder is most likely gone and you’ll need to recreate it. Simply create a folder with your domain name (no www prefix) in your root folder and a folder called htdocs inside that folder and upload a file there.
@Admin said:
@KhenPlay said:
I saw one of my added domains folder but I can’t find the other one.In that case, the folder is most likely gone and you’ll need to recreate it. Simply create a folder with your domain name (no www prefix) in your root folder and a folder called htdocs inside that folder and upload a file there.
okay, I will reply later on for the result.
It’s working, thanks a lot!
