Error 500
jet2.epizy.com
Error 500
Website fails to load so I created a subdomain - test.jet2.epizy.com and copied the same files from htdocs to the subdomain and it worked perfectly, but why will it not work on the main domain?
Works like a charm for me! Try clearing you cache.
Read this then
Thanks I’ll have a look, but strange as to why it works on a subdomain with the same files?
If the files are exactly the same, then you must have a configuration error somewhere. Are you using a specific piece of software on your site?
Was that the Jet2 site or the test.jet2?
Test.jet2 is the subdomain I setup to test and works perfectly. The main domain Jet2 is the one giving the error although I copied all the files from the Jet2 main domain and pasted them into the subdomain and yet it worked. So the issue has to be someone on the main domain and not with my files
Can you try completely re-installing the software on the domain you want it on?
Hi, I tried that with the same results. A fresh install returned a 500 error but on the subdomain it installed with no problem
If it is installing just fine on the subdomain, but not the main domain, that would be a install issue, and there is nothing we can do. You have two options at this point.
(1) - Try to figure out what the cause of the cause of the issue is and fix it
(2) - Just use the working instance instead, and create a redirect from the other domain to it.
Please let me know if you have any questions!
Yeah when I transfer the install files and try to load the install.php file it returns a 500 or 404 error I think and wouldn’t start the install process.
I’ll see if I can figure out a redirect, main this it’s working somewhere
For the redirect, just add the following code to your index.php file on the non-working page.
<php
header('Location: test.jet2.epizy.com');
I tried this, but still a 500 error
On jet2.epizy.com, delete all of the files, and create a new “index.php” file with only the code above.
This should be:
<?php
The first question mark was missing, and the PHP closing tag is not necessary.
