HIDDEN DUE TO ORIGINAL POSTER'S REQUEST
is saying cloudflare Error 521. Getting message -
Server unreachable
Your web server at 185.27.134.200:80 was unreachable (returning Error 521) on August 11, 2020 10:35 PM (GMT+5:30).
All seems normal in control panel. No deactivation history etc. Please help
Please check this:
Hey there,
I just contacted iFastNet because there are 3 topics with the same issue. There are some problems that they are aware and they will fix them as soon as possible.
Please be patient.
Best Regards,
Dimitris
Thanks for quick response. So i can just wait as its its the company (ifastnet) issue right ??
Yes. You can mark the issue as resolved if you want and have patience.
I hope that I helped you.
Thanks. But its showing me host error.
What error? As I mentioned you must wait for the issue to get fixed.
Yes. This is the error I mentioned. Just because you use cloudflare the error shows like this. Otherwise you would get a “Connection Refused” error.
Kindly wait for the issue to get fixed
Hello, As Dimintris says, the server hosting node you are on ( 185.27.134.200:80) appears to be having issues, generally this takes less than an hour, but can stretch to 2 days, generally, patience is key!
Hmmmm just hoping to get it fixed ASAP
Can u please remove my site url from the upper post because its hampering SEO
system
Closed
September 1, 2020, 5:29pm
#13
