My website URL is:
What I’m seeing is:
error 520
I’m using this software:
wordpress
Additional information:
My website URL is:
What I’m seeing is:
error 520
wordpress
I’m facing the same issue with my websites
www.sunilkrishnan.in
www.work.sunilkrishnan.in
Any idea how to fix it? I’m following this thread to find a way fix it.
I was having the same problem since I created my website on infinityfree.net yesterday. I hope @Admin replies with a solution
www.9amer.com
The issue is that the IP address your website is on is currently being targeted for a DDoS attack. Because of that, the IP address had to be disabled to prevent damage to the system as a whole. The issue is being monitored, and the IP address will be re-enabled as soon as the attack has subsided.
Note that this does not mean your website specifically is the target of the DDoS attack. We host a lot of different websites on specific IP addresses, so it’s likely that another website was the target instead, and this is just collateral damage.
@Admin is this answer to all above three queries? Please specify, can you please check my website work.sunilkrishnan.in & sunilkrishnan.in too?
It was almost a week ago, so I think it was.
And your website is working fine from here.
