Whenever I try to use the Full or Full (Strict) SSL mode on Cloudflare, it doesn’t work. I know I can use flexible but using Full or Full Strict is mandatory for protecting extremely sensitive data that will be transferred from the Origin Server to Cloudflare.
I joined InfinityFree a few days ago and I don’t know how to fix this problem. Thanks in advance!
A most common problem when you don’t configure your website with Cloudflare correctly.
I think you are using cloudflare integration from vPanel and trying to use full SSL.
Use flexible SSL from cloudflare SSL settings it will fix the problem.
Or try what @KangJL set for full SSL Settings.
Or Install valid SSL on your site for Full (Strict) SSL Settings.
You can generate certificate from CloudFlare Dashboard → SSL/TLS → Origin Server and use it for Full SSL settings to work with cloudflare
If you use flexible, whats the point of having an SSL on IF? I dont think it will do anything. Set it to full, and than wait. Sometimes it takes a little bit to start working.
