What I’m seeing is:
I’m using this software:
Additional information:
i got ERROR 525. How to solve?
To fix that error you need to set the SSL option to “Flexible” on the “SSL/TLS” section of the Cloudflare dashboard for your domain, and then if you use WordPress also follow this KB article.
where i can find SSL? In cpanel or cloudfare?
I edited the post with the answer, but I will post it again:
